Kicks10
Mar 19, 2020Guide
RAX120 constantly dropping WiFi until reset
I have had the RAX120 for about 7 months now with no issues. I started working from home three days ago with no issues. Then yesterday and today all day my router would stay connected but lose Interne...
ricachica82
Mar 23, 2020Initiate
I’ve owned this router for two weeks, and it has done this same thing to me, then factory reset on me twice when I unplugged it, forcing me to completely set up my router again from the beginning. I have gig fiber service with a static IP address. For as much as I spent on this thing, I’d hoped for more stability.
- NewfiedroolMar 23, 2020Virtuoso
ricachica82 wrote:
I’ve owned this router for two weeks, and it has done this same thing to me, then factory reset on me twice when I unplugged it, forcing me to completely set up my router again from the beginning. I have gig fiber service with a static IP address. For as much as I spent on this thing, I’d hoped for more stability.there is an update here, download and install.
https://www.netgear.com/support/product/RAX120.aspx#download
Perform a factory reset after updating, use the rear pin hole method and setup as new. Do not use a saved config.
