Kicks10
Mar 19, 2020Guide
RAX120 constantly dropping WiFi until reset
I have had the RAX120 for about 7 months now with no issues. I started working from home three days ago with no issues. Then yesterday and today all day my router would stay connected but lose Interne...
Sethers
Mar 26, 2020Aspirant
I have the same problem where it started 4 days ago. Internet suddently cut out i rebooted the touter then it went again. i called net gear and they informed to roll back the hardware to previous version. which i did but still not working, is worse now it use to just cut out now it randomly resets to default. anyone have a fix? i told the suport about this post here but she does not admit that netgeat knows about this problem. anyone help? i do wish they can fix this.
- Kicks10Mar 26, 2020Guide
Sethers wrote:I have the same problem where it started 4 days ago. Internet suddently cut out i rebooted the touter then it went again. i called net gear and they informed to roll back the hardware to previous version. which i did but still not working, is worse now it use to just cut out now it randomly resets to default. anyone have a fix? i told the suport about this post here but she does not admit that netgeat knows about this problem. anyone help? i do wish they can fix this.
I would try factory reset on your router. It worked for me. Don't just reboot, but use the pin hole method.
- SethersMar 26, 2020Aspirant
my device is factory reseting it self... i baught a new one and still do the same thing
- NewfiedroolMar 27, 2020Virtuoso
Sethers wrote:my device is factory reseting it self... i baught a new one and still do the same thing
Did you reset the device after any updates and when setting up did you use a saved config.
