Kicks10
Mar 19, 2020Guide
RAX120 constantly dropping WiFi until reset
I have had the RAX120 for about 7 months now with no issues. I started working from home three days ago with no issues. Then yesterday and today all day my router would stay connected but lose Interne...
ironadam1120
Mar 28, 2020Initiate
Hi! I'm having the same issue as others. On firmware 114 or 118, wifi drops out. on 84, it did not. I'm trying 108 now per tech support. The larger issues is that upon any reboot, the route goes back to factory settings and i have to start over, which is very frustrating.
Support was not helpful. they did not understand the main issue was going back to factory default settings on a reboot. they seemed to be fine when i explained my internet worked now AFTER downgrading firmware to 4 versions prior so i don't have to reboot to get wifi to work (and rebooting caused everything to go to factory default settings). Hoping someone here has better luck than I did.
- MAG39MarineMar 28, 2020Aspirant
I was on 114 and rolling back to 108 and changing DNS didn't help. Pushing in the reset button and re-setting up (which forced an upgrade to 118) seems to have resolved...2 days and no problems.
- TjholbrookMar 28, 2020InitiateHelps to reset with the small button then reset it up this will be the last thang I try it seams to be working
- PigletRiderMar 29, 2020Apprentice
As others have noted on this thread, bouncing back to an older release, followed by an upgrade to the latest release (e.g. .118), followed by the pin-hole factory reset, works for many of us. I've been up for a couple weeks now with no resets, connection drops or speed degredation. Admittedly this may not work for all.
This all has to be a GIANT clue for the developers at Netgear. Your upgrade, reboot, reset processes are hosed. Can you PLEASE white-box test these scenarios, find the bug(s) and release a firmware version with the fix. Your customers should be able to simply upgrade to the latest release, via the app, without any issues, no downgrades or factory resets required. Can you make that happen?
