Kicks10
Mar 20, 2020Guide
RAX120 constantly dropping WiFi until reset
I have had the RAX120 for about 7 months now with no issues. I started working from home three days ago with no issues. Then yesterday and today all day my router would stay connected but lose Interne...
undeadhaggis
Apr 01, 2020Aspirant
Yes, I have tried the factory reset 4-5 times now where I use a paperclip to push down the reset button on the router. Unfortunately that has never solved the problem for me. I also tried the 30-30-30 reset as suggested by others, but that didn't work either. I'm hoping I just have a defective device and the RMA replacement that should arrive soon doesn't have the same problem. If so, I will definitely not be buying a Netgear device again...way too many problems.
Kicks10
Apr 01, 2020Guide
undeadhaggis wrote:Yes, I have tried the factory reset 4-5 times now where I use a paperclip to push down the reset button on the router. Unfortunately that has never solved the problem for me. I also tried the 30-30-30 reset as suggested by others, but that didn't work either. I'm hoping I just have a defective device and the RMA replacement that should arrive soon doesn't have the same problem. If so, I will definitely not be buying a Netgear device again...way too many problems.
Sorry to hear that. Have you tried changing your DNS settings yet? That kept me stable prior to factory reset. 1.0.0.1., 1.1.1.1
