Kicks10
Mar 19, 2020Guide
RAX120 constantly dropping WiFi until reset
I have had the RAX120 for about 7 months now with no issues. I started working from home three days ago with no issues. Then yesterday and today all day my router would stay connected but lose Interne...
Tommy1981
Aug 03, 2020Guide
Manually update firmware with a laptop. Do not use the Nighthawk or Genie app.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
I started having the same problems. I will guide you through the initial steps of connecting your router to your laptop.
You may have to go to a friends house with internet.
1) I first disconnected my AX4 router from my modem and then restarted it.
2) Next I reset my AX4 nighthawk to factor settings by pushing the reset button (the small hole on the back). It takes a few minutes to restart. I held the button for 10 seconds then released it and this started the reset process.
3)Furthermore, I connected my laptop to my wifi connection (I used my old router. If you don't have a wifi connection, I recommend going to a friends house who has wifi).
3) Moreover, I connected my router, that is currently powered on with all of the LEDs green except of course the internet one, to my laptops ethernet port. Ethernet cable is in port 1 on the Nighthawk router.
You are now ready to continue with installing the firmware. See the link above. Start on step 2.
