dj2819
May 01, 2020Apprentice
RAX120 DHCP Issues
I first want to say I been using Netgear products since the 54g days so I am familiar with them. However ever since I got FIOS back on 08 I haven’t used my Netgear routers as DHCP servers. My la...
- May 21, 2020
I guess the solution would be avoid the RAX120 and possibly the RAX line until they fix their firmware. Networks with many always on devices will stuggle with this router. Netgear really needs to listen to the reviews and user feedback because something is clearly wrong with this device.
Switched to the Linksys Velop MX5 and everything works perfectly right out of the box (thank god because custom settings on it is non-existant).
So long Netgear, it was a nice decade of relible devices.
dj2819
May 04, 2020Apprentice
The DHCP issues returned eventually even with IP reservation so I gave up on Netgear as a DHCP server. To be frank I don't even remember the last time I used the DHCP server of Netgear as the Fios router always handled that for me since 2009.
Well I broke out my old Fios router, set up the RAX120 in AP mode and no issues so far. Everything has been rock solid for about 2+ days of uptime.
netgear You really need to double check your DHCP server firmware code on your routers. I believe there is something seriously wrong in your new devices when multiple devices are involved. It sucks that these expensive routers can't handle the simple task of DHCP...
- dj2819May 11, 2020Apprentice
Update: Even with the Fios router I faced some issues but not as bad as the original disconnects. I replaced the Fios router with an EdgeRouter ER-X. So currently the EdgeRouter acts as the DHCP server and the RAX120 is just in AP mode.
What I learned is given 1-2 days from the original DHCP lease, the iPhone 11s or one of the 7 HomePods I have randomly lose connection.
The iPhones show as connected in the OS but the router's GUI nor pinging their IPs does not work. Flipping the iPhone's Wi-Fi on and off fixes the issue until another day or 2 later.
The HomePods face a similar issue where they lose connection (no OS GUI to check if its actually showing as connected) and they are not pingable.
Window's PC shows as connected with no internet
I am getting fed up with this router. I had Amazon send me a replacement. If that doesn't work I will try to turn of AX features. If that doesn't work then goodbye netgear (after a whole decade of their products)
- RobdarftwMay 20, 2020Initiate
dj2819 Hey hope you get this message.
I am having the exact same issue and about the same setup. I have about 3 or 4 wired connections (2 of which are connected to a Nighthawk switch) and the rest are on Wi-Fi with AX mode enabled.
What's weird is, only my wired connections seem to be affected are straight up losing DHCP and not getting a new IP from the DHCP server - in this case the Netgear Nighthawk RAX120 - even with a release/renew.
I have the updated firmware that was released a few weeks ago, and I have recently added a Google Home to my network, but thats the only thing I can think of that has changed.
When I get home I am going to try to reset the RAX120 and set it up from scratch, as those DHCP reservations aren't doing a darn thing.
I'll let you know if I find anything else.
-Rob
- dj2819May 20, 2020Apprentice
Hey Robdarftw, sorry I haven't updated this thread in a long time.
I been posting updates on other threads. Basically I don't think it is a DHCP issue for me anymore. Using a EdgeRouter X as the DHCP server I experienced the same issues. I think DHCP has something to do with maybe collisions or some conflict on the network because when I decreased the DHCP lease time to 1 hour (from 24 hours) the issues happened more frequently (within 4-5 hours).
Then I realized this might just be an issue with the 5Ghz band.
I tried getting in touch with Netgear support but oh what a **bleep** show that was. I had ONE (the first) phone tech who was profressional, accepted that I knew what I was doing, listened to the month of troubleshooting I did (which was the same questions/steps he was going to present to me) and said the ticket needs to get escalated. However that case got closed (for whatever reason) and the new ticket I opened got no responses after I explained the same situation. Calling again resulted in them hanging up on me or dropped calls when they transfered me to the RAX dept.
The second case rep suggested I isolate all my devices to one band. So I moved everything to the 2.4ghz band and left one device on the 5Ghz band. Weird thing was I saw the same issue occur on the 5Ghz band and once on the 2.4ghz band (but much less frequently).
I then tried something I wish I tried earlier. When I upgraded from my old router to the new one, I set the new one with the same SSID and PW. I tried another factory reset and kept the default wifi settings. This didn't help either.
So where I am now is I have just setup the Linksys Velop MX-5 as an AP. If this works without issue then goodbye Netgear. I really tried for over a month to keep this product because I have brand loyalty. But Netgear doesn't give two sh*ts and my experience with their past 2 generation of products was really bad. I really hope this new router works so then I can narrow the issue to the router and not the devices....
