additude
Aug 04, 2019Virtuoso
RAX120 DHCP Reservation Limitation
I am setting up a new $400+ RAX120 and while setting up the DHCP Reservations list I think I discovered that there is a 15 character limitation on the item description and I also think that there is a limitation on the number of reservations I can enter. I am moving settings over from a NetGear DGND 3700 router that does not appear to have these limitations.
So is the RAX120 limiting my requirements in respect to DHCP Reservations?
Is it possible for me to change the limitations? Can I make changes to the firmware myself?
Thanks.
Sort By
- additudeVirtuoso
...and By The Way...
I have read the manual and I have searched for an answer to this and I was unable to find any information regarding limitations.
- IrvSpMaster
Better off posting here, https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6, which is the proper support forum for this product.
- additudeVirtuoso
- SAGHIAspirant
