pjd813
Jun 27, 2022Guide
RAX120 does not keep WAP2~WPA3 Personal settings
When I try to set WPA to anything other than WPA3 the setting always goes back to WPA3. I have an 8 year old Logitech Universal Remote that uses WiFi and I believe the WPA setting may be causing issu...
- Jun 27, 2022
Thanks for the question about browser vs. App. I was using Safari thru iPadOS so I tried the Nighthawk app and the WPA2+WPA3 setting now looks like it is “sticking”. That also seems to have fixed the Logitech connectivity issue.
Jun 27, 2022Guru - Experienced User
Are you doing it through the browser?
through the app?
Have you tried a different pc and/or browser?
pjd813
Jun 27, 2022Guide
