NOiSEA
May 08, 2020Guide
RAX120 does not work with AX200 160Mhz
When will this be fixed? I have been patient, waiting for this to be fixed in a router firmware update, but how much longer do we have to wait? I bought this router thinking that it would be compatib...
NOiSEA
May 10, 2020Guide
The AX200 do not have connectivity issues -just the speed drop issue where it drops to less than 1% of normal speeds. You don’t see the speed drop right away - usually takes about 2 hours - sometimes more.
If you are having to use an older driver , are you even able to get the 500-600Mbps speeds that you would normally get? If not then I don’t see a point in using an ancient driver.
Johnyman
May 11, 2020Tutor
Yes it can still achieve 900Mbps. You might want to read my post here. https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Speed-issues-with-RAX120-as-AP/
