NOiSEA
May 08, 2020Guide
RAX120 does not work with AX200 160Mhz
When will this be fixed? I have been patient, waiting for this to be fixed in a router firmware update, but how much longer do we have to wait? I bought this router thinking that it would be compatib...
dcinca
May 13, 2020Apprentice
I had the similar problem.
It's caused by the driver of AX200
Use the Killer AX1650 beta drive, https://support.killernetworking.com/software/
install the Killer Control Center
How?
Method:https://blog.csdn.net/u014390186/article/details/103423636
It's in Chinese, but a lot of pictures to show how to do it, I think it's ok to who can't read chinese.
or you can try to search the method from google.
- NOiSEAMay 13, 2020GuideMy solution is that I created a .bat that I mapped to a macro key on my keyboard to quickly disable and then re-enable my wifi adapter.
Whenever my speed drops, I quickly hit the key and it fixes it before I even get dropped from a game or call or chat or whatever I’m doing. Its not ideal And its immensely annoying but its all I can do until Intel and Netgear get their acts together.- BorazJul 14, 2020AspirantWere you able to resolve this? I'm having the same issue with the TP-LINK PCI ax200 wifi adapter and the RAX120 router in AX mode. My desktop PC connects to the 5G network, seems to work, I do a Speedtest, and after it hits around 850-900Mb/s the connection drops to almost zero. Then I have to do the same workaround you mentioned, with disable/re-enable the device. It's super frustrating as this is the only reason I bought this router.
- avtellaMay 13, 2020ProdigyYou do know Killer just reuses drivers from Intel, but yeah you can use the beta drives as they’re just Intel stock drivers. I would however definitely not install the Killer Control Center software it’s snake oil and has cause more people issues than good. The software is Killer’s only real product as the cards and drivers are the same as standard Intel 9260/AX200 or Qualcomm 6174A parts.
- NOiSEAMay 13, 2020GuideYeah I definitely wouldn’t install software from a company in a country that requires developers to share encryption keys and backdoors with the government. You don’t have to convince me.
