NOiSEA
May 08, 2020Guide
RAX120 does not work with AX200 160Mhz
When will this be fixed? I have been patient, waiting for this to be fixed in a router firmware update, but how much longer do we have to wait? I bought this router thinking that it would be compatib...
dcinca
May 13, 2020Apprentice
I had the similar problem.
It's caused by the driver of AX200
Use the Killer AX1650 beta drive, https://support.killernetworking.com/software/
install the Killer Control Center
How?
Method:https://blog.csdn.net/u014390186/article/details/103423636
It's in Chinese, but a lot of pictures to show how to do it, I think it's ok to who can't read chinese.
or you can try to search the method from google.
avtella
May 13, 2020Prodigy
You do know Killer just reuses drivers from Intel, but yeah you can use the beta drives as they’re just Intel stock drivers. I would however definitely not install the Killer Control Center software it’s snake oil and has cause more people issues than good. The software is Killer’s only real product as the cards and drivers are the same as standard Intel 9260/AX200 or Qualcomm 6174A parts.
- NOiSEAMay 13, 2020GuideYeah I definitely wouldn’t install software from a company in a country that requires developers to share encryption keys and backdoors with the government. You don’t have to convince me.
