alud7_ru
Jul 27, 2020Aspirant
RAX120 doesn't save and/or edit port forwarding setings
Recently updated to FW 1.0.1.122 and found out that the router cannot add, edit, save port forwarding settings. Thanx god it has the earlier entered settings, otherwise I don't know how I would work. ...
Christian_R
Jul 30, 2020NETGEAR Employee Retired
Hi alud7_ru,
Did this issue occur with previous firmware versions? You may try reverting back a firmware version to see if the issue persists.
Christian
Pistole
Aug 04, 2020Guide
Yesterday I did a factory reset because I wanted to clean install the router. After the reset the devices list on my MacBook kept empty and I cloud not create any port forwardings.
On the IOS app the list was normal filled.
I have installed the previous Firmware Version V1.0.1.115 and the list was again filled with my devices. I updated again to Firmware Version V1.0.1.122 and the list was again empty.
Rest me no other option than again go back to Firmware Version V1.0.1.115 and keep working on that version.
There is something very broken in the Firmware Version V1.0.1.122.
