danielshaw007
May 01, 2023Aspirant
RAX120 drop internet, comes back after reboot
Hi all. I have a RAX120 v1 router, its been fine for over 2 years. Lately, my internet seems to die. Wifi connected, without internet access. I reboot the ONT and same issue persists, then I reboot t...
danielshaw007
May 10, 2023Aspirant
Pin push factory reset seems to have improved things. No need to have power cycled the router in the last 7 days and I have found some extra speed too which is a bonus!
Will see how it goes due course. Thanks for the tips
May 10, 2023Guru - Experienced User
So you just FR and setup from scratch. No FW update?
- danielshaw007May 10, 2023Aspirant
Pretty much. Router was on latest public fw, I think I once updated it via the app and never factory reset it since then. Perhaps that is all it needed.
- FURRYe38May 10, 2023Guru - Experienced User
Kewl. Good to hear.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- danielshaw007May 14, 2023AspirantHi again. Been looking at the log on the router today as noticed occasional connected with no Internet messages on my phone.
Every 10 to 30 or so mins there is a line saying "Internet Connected, then my IP and date and time"
Does this indicate the wan keeps dropping and reconnecting ?
Thanks
