Ambassadeur
Dec 22, 2021Tutor
RAX120 dropping 5Ghz randomly
Hi everyone, I installed recently my new AX12 RAX120 router (in access point only mode) on my network. Performance wise it's perfect but I encountered a very annoying problem recently : randomly (bu...
Dec 22, 2021Guru - Experienced User
If you downgrade the firmware, does the problem go away?
- AmbassadeurDec 23, 2021Tutor
did not tried a downgrade because it's a new device that came with the latest firmware installed. I'm not sure if older firmwares are still available to download. If that's the case, is there a specific version that is supposed to be more stable than others?
- FURRYe38Dec 23, 2021Guru - Experienced User
- wcalifasDec 25, 2021Prodigy
You can find all firmwares for your router in the netgear.com webpage under the support section. Just type in your router model and click on downloads, you'll find them there. You will need to apply them manually, and if I recall correctly you do that under the administratiion tab on your router.
