MCBurn
Mar 10, 2020Star
RAX120 Dropping Speed
A day into my new RAX120 and I'm running into issues with WiFi dropping speeds down to 20/30 Mbps or dropping connection altogether on 5GHz. Upon reboot, speeds come back to normal which on WiFi devi...
Retired_Member
Oct 07, 2020For this so expensive router, after the latest firmware I noticed a big drop on my 1000 mbps fiber speed. I revert the firmware to the stock firmware and never use their nighthawk app and it seems I never had any issues at all. This bitdefender software is just one of their moneymaking styles. Correct me if I'm wrong.
Killhippie
Oct 08, 2020Prodigy
All netgear firmware is stock! Bitdefender is a AV comany and not a 'style' but if you have multiple pc's and IoT devices it will offer protection as you can download Bitdefender for as many devices as you want for that one price. Its not really that useful on the router alone but does offer basic protection basically.
