jayman4x4
Jun 28, 2019Aspirant
RAX120 drops high speed internet connection, but reboot restores it
I recently installed a RAX120 and it works great for about 18-24 hours then the connection speed drops off to super slow under 10mbps. It is just the download speeds no the upload and my ISP plan is...
- Jun 29, 2019
Jayman4x4...
I have approximately the same setup as you do and I haven’t been able to get close to my 400M down connection speed yet through the RAX120... I can get 80-100 down on good days. So I’d say you are ahead of the game!! Lol.... Oddly my upload is right on or above my 20M plan. It is just the download side that sucks. I have done the same TSing as you... still no improveent - even with a reboot. I’m geting frustrated as hell with this router. I had a faster, more reliable network with my WRT1900AC router...
jayman4x4
I'm testing within the Nighthawk app which connects back to the hardware itself. I can get 480 on a 400 connection there for 18-24 hours then it drops down but upload stays hgh. Typically, I'll then try hardwired on the pc connected via cat7 network cable and get the same measured result when it is running slow. I get near the same low speed running the speedtest app on my iphone connected to the 5ghz wifi too. A reboot of the router makes everything cruise at 480 again.
kermitWyo
Jun 29, 2019Aspirant
Jayman4x4...
