speedi1
Jan 16, 2023Tutor
RAX120 Ethernet ports max 130Mbps?
I have an issue that I just started experiencing with my RAX120 -- the Ethernet ports will not longer go about 130Mbps when I doing a speedtest through Windows 11. The wireless 5GHz speedtest still g...
speedi1
Jan 16, 2023Tutor
Thanks.. you definitely made me double-check. It's Mbps, not MB/s.
Jan 16, 2023Guru - Experienced User
have you tried a different wired device?
And/or website and browser?
- speedi1Jan 16, 2023Tutor
Yes.. I have two desktop PCs sitting here next to one another.. I've even tried switching Ethernet ports to no avail. Same result. Also tried different browsers, but was still using Speedtest.net. 🤔
- plemansJan 16, 2023Guru - Experienced User
What does your statistics show for connected port speeds?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
IF its hitting 130, its negotiating gigabit because it'd max out at 94mbps on the 10/100mbps connection.
Did you try a factory reset?
Are you using qos?
