darkroute
Sep 28, 2019Follower
RAX120 Fan Settings
I am trying to prevent the fan from spinning up too often and I found out about the following settings page: http://routerlogin.net/Thermal_FAN.htm but applying any of the settings leads to a...
dmystic1
Sep 29, 2019Apprentice
I have yet to hear the fan.
- chuck4100Dec 31, 2019Tutor
Having this issue aswell.
- Jacek26Jan 11, 2020TutorI have RAX80 the only way I would hear my fan is when I unplug the router and plug it back in when I want to reset the router. But also I have raised the router on applied “feet” to raise it off the flat surface that way there is some air ventilation between the router and my desk. The RAX80 was getting very hot while sitting on flat surface but yet the fan didn’t kick on so I raised it, router stays cool but like I said earlier I have yet to hear the fan only on reboot.
