darkroute
Sep 28, 2019Follower
RAX120 Fan Settings
I am trying to prevent the fan from spinning up too often and I found out about the following settings page: http://routerlogin.net/Thermal_FAN.htm but applying any of the settings leads to a...
arjewell23
Feb 22, 2020Star
I stumbled upon your post because my router RAX120 has been running hot and the 5GHz keeps going out. I found some info somebody else posted about their system getting hot. Try "ip address/debug.htm". I found a setting that says " Always enable Fan". I checked it and hit apply and it looks like the setting stayed. I just checked the fan and holy crap, it's on! HOT air is coming out and I hope this fixes the performance issues. I have a feeling the 5GHz radio was turning off due to overheating.
chuck4100
Feb 23, 2020Tutor
Wow! Thank you so much!
This is also working for me. never before had the fan come on but it is now. I'd rather it run at all times and fail eventually than let this over priced router sit hot and slowdown.
thanks again for responding
- arjewell23Feb 24, 2020Star
You are very welcome! I agree 100%. I want all my equipment to run as cool as possible.
