darkroute
Sep 28, 2019Follower
RAX120 Fan Settings
I am trying to prevent the fan from spinning up too often and I found out about the following settings page: http://routerlogin.net/Thermal_FAN.htm but applying any of the settings leads to a...
arjewell23
Feb 22, 2020Star
I stumbled upon your post because my router RAX120 has been running hot and the 5GHz keeps going out. I found some info somebody else posted about their system getting hot. Try "ip address/debug.htm". I found a setting that says " Always enable Fan". I checked it and hit apply and it looks like the setting stayed. I just checked the fan and holy crap, it's on! HOT air is coming out and I hope this fixes the performance issues. I have a feeling the 5GHz radio was turning off due to overheating.
CrownDreams
Mar 30, 2020Aspirant
Thanks a bunch! Bookmarked! It appears the fan will go back to default the next time you unplug, turn off/on or reboot the router.
I'd also would want the fan to run 24/7 than 5g slow down.
- arjewell23Mar 31, 2020Star
You're welcome! Yes, I did notice that as well. I have the RAX120 striclty as a router now and use a DHCP server along with AX6000 as my wireless APs. This way, I rarely have to restart the RAX120 and can keep the fan going. Because it was getting so hot, I bought some mini fans that hook up to the USB. They are loud but I have my RAX120 in the basement / Utility Room will all of my other equipment so I never hear it and it's been running great!
- TopologyMar 31, 2020Virtuoso
Arjewell23, you may find the USB component fans by AC Infinity to be of interest.
Thank you so much. I will be purchasing a few of those for my equipment!
