darkroute
Sep 28, 2019Follower
RAX120 Fan Settings
I am trying to prevent the fan from spinning up too often and I found out about the following settings page: http://routerlogin.net/Thermal_FAN.htm but applying any of the settings leads to a...
Mojofilter99
Jun 14, 2020Aspirant
Looking through my setting trying to figure out where the enable/disable setting is for my router because my cooling fan never comes on and from reading other posts, it looks like there might be an option to enable/disable, I just can't seem to find it.
- chuck4100Jun 15, 2020Tutor
if you goto
http://192.168.1.1/debug.htm
it will have an option to always enable fan, however, it will go to default if the router is turned off/restarted. - Raiden85Jun 15, 2020Star
Don't have any access to fan controld on the RX200 either, really wish Netgear would make all these hidden pages part of the advanced settings for a start, what's the point in hiding them?
For such expensive routers it would be nice to have a UI with a lot more options and visibilty of what the router is doing, would be nice to see the CPU temps or overide the fan speeds if we wish at least.
So many things they could add, even the advanced settings in these routers are ultra basic. Why can't I see the link speed of atttached devices either?, as you can from the iOS app, how much bandwidth is each device using?, guess we'll never know.
