darkroute
Sep 28, 2019Follower
RAX120 Fan Settings
I am trying to prevent the fan from spinning up too often and I found out about the following settings page: http://routerlogin.net/Thermal_FAN.htm but applying any of the settings leads to a...
Mojofilter99
Jun 14, 2020Aspirant
Looking through my setting trying to figure out where the enable/disable setting is for my router because my cooling fan never comes on and from reading other posts, it looks like there might be an option to enable/disable, I just can't seem to find it.
chuck4100
Jun 15, 2020Tutor
if you goto
http://192.168.1.1/debug.htm
it will have an option to always enable fan, however, it will go to default if the router is turned off/restarted.
