darkroute
Sep 28, 2019Follower
RAX120 Fan Settings
I am trying to prevent the fan from spinning up too often and I found out about the following settings page: http://routerlogin.net/Thermal_FAN.htm but applying any of the settings leads to a...
Mojofilter99
May 19, 2021Aspirant
What is the setting to get into fan control? I would set mine to always on.
Jacek26
May 19, 2021Tutor
http://192.168.1.1/debug.htm
it will have an option to always an able to fan but if you reset or turn off the router the settings go back to normal.
Also what I did I have set the router on a raised legs. It’s not sitting flush to the shelf I have it raised so the heat dissipates from the bottom as well as the top. Hence my router stays cool. Before I did that it ran very hot
