darkroute
Sep 28, 2019Follower
RAX120 Fan Settings
I am trying to prevent the fan from spinning up too often and I found out about the following settings page: http://routerlogin.net/Thermal_FAN.htm but applying any of the settings leads to a...
mudbone
Dec 08, 2021Apprentice
Use "192.168.1.1/debug.htm" to get to the debug page. Just check the box labeled "Always enable fan". If you reboot the modem this will get unchecked so you will have to keep checking it. Do not click the apply or save buttons. I made that mistake and it actually saves other unwanted settings. Not sure why the firmware developer does not put this setting in the unhidden pages. This thing gets hot so I guess they want it to burn up sooner so you have to buy another one. I have my router sitting on a short shelf so I can not raise it up higher and do not want to relocate it.
Dec 09, 2021Guru - Experienced User
This is a router and not a modem.
If users want to avoid having the router reboot and having to re-enable the FAN setting, as a alternative suggestion, one can install a USB laptop fan cooler under any router and have 24/7 forced air induction all the time. I keep on user my router. Works well.
