Topology
Apr 27, 2020Virtuoso
RAX120 Firmware 1.0.1.122 (27 APR 2020)
NETGEAR has released new firmware for the RAX120 (see here): New Features and Enhancements * Supports NETGEAR Armor * Improves the device type and model detection Bug Fixes * Clients were una...
PigletRider
May 03, 2020Apprentice
Has anyone figured out the ReadyCloud issue on this latest version of the fimware (.122)? ReadyCloud can no longer access my attached USB drive. Apparently this is a known issue.
Has anyone worked around this issue yet?
Netgear... can you please respond?
- dj2819May 06, 2020Apprentice
.122 has been stable for the most part and the fix for DoS attacks in the logs looks like its fixed because I saw a lot more DoS logs than before.
However my issues with the DHCP server were not fixed and still had those same issues. I was able to resolve those by just switching the RAX120 to AP mode and using a EdgeRouter X as the DHCP server that seems to work really well. Still can't believe I paid $400 for a router that can't behave as a router...
Interesting that with .122 with DHCP enabled used 420-430mb of ram. With DHCP off it only uses 360-380mb of ram. Didn't know the DHCP server would take up so much memory.
