Topology
Apr 27, 2020Virtuoso
RAX120 Firmware 1.0.1.122 (27 APR 2020)
NETGEAR has released new firmware for the RAX120 (see here): New Features and Enhancements * Supports NETGEAR Armor * Improves the device type and model detection Bug Fixes * Clients were una...
kc6108
Jun 08, 2020Luminary
After upgrading to 1.0.1.122 my Attached Devices page is showing blank as well. Same for the Nighthawk app. The number of devices on both the website and app are populated.
I tried performing a factory reset after a few days, but am seeing the same results as above. It's been over 24 hours since I performed the factory reset. I thought it may take a little time for the information to populate, but that doesn't seem to be the case.
ZacksFair
Jun 08, 2020Aspirant
My RAX120 USB device work normally when I use Mac Samba to access, but when I use iOS to access, it’s normal to read file, but it’s can’t copy files from iOS to USB, neither copy or duplicate files inside USB, says “Bad file descriptor”, I tried to roll back the firmware to 118 version and test it, nothing changed, I’m confused.
- ZacksFairJun 08, 2020AspirantBTW I use Linksys WRT32X Openwrt router to access the USB device all functions are perfect with iOS and Mac.
