Topology
Aug 11, 2020Virtuoso
RAX120 Firmware 1.0.1.128
A firmware update (see here) is now available for the RAX120: New Features and Enhancements Supports the ISP profile menu, which includes ISPs from Europe and Asia Supports Orange France IPTV ...
Christian_R
Aug 13, 2020NETGEAR Employee Retired
Hi Topology,
Thanks for sharing for others to view!
Christian
Topology
Aug 19, 2020Virtuoso
FYI: The RAX120 firmware 1.0.1.128 appears to be stable, with no issues observed to-date after one week of use.
- LurksalotAug 19, 2020Apprentice
Hi Topology,
Assuming you performed a factory reset as well. Did you restore your settings manually or from a settings backup?
In some previous post others have suggested not restoring from a backup, otherwise it could reintroduce problems.
Please advise.
-Thanks.
- TopologyAug 19, 2020Virtuoso
Lurksalot, for the RAX firmware 1.0.1.128 upgrade, I simply downloaded the new firmware to my PC desktop, extracted the RAX120-V1.0.1.128.img file, and installed it using the "ADVANCED | Administration | Firmware Update | Locate and select the upgrade file on your hard disk" process. At least in my case, a factory reset did not appear necessary.
- iKarelAug 20, 2020Aspirant
Hello,
does readycloud work for you? It does not work for me.
Thanks
- NmouneimneSep 06, 2020Apprentice
Time Zone location will not stick. Anyone else?
