Topology
Aug 11, 2020Virtuoso
RAX120 Firmware 1.0.1.128
A firmware update (see here) is now available for the RAX120: New Features and Enhancements Supports the ISP profile menu, which includes ISPs from Europe and Asia Supports Orange France IPTV ...
Topology
Aug 19, 2020Virtuoso
Lurksalot, for the RAX firmware 1.0.1.128 upgrade, I simply downloaded the new firmware to my PC desktop, extracted the RAX120-V1.0.1.128.img file, and installed it using the "ADVANCED | Administration | Firmware Update | Locate and select the upgrade file on your hard disk" process. At least in my case, a factory reset did not appear necessary.
iKarel
Aug 20, 2020Aspirant
Hello,
does readycloud work for you? It does not work for me.
Thanks
- LurksalotAug 20, 2020Apprentice
After updating firmware last night ReadyCloud fix is not working, otherwise everything else is working smoothly.
This evening I plan to perform a factory reset to see if that helps.
Are others experiencing ReadyCloud fix after updating firmware and performing a factory reset?
-Thanks.
- avtellaAug 20, 2020Prodigy
I downloaded it on release day, no major issues since, then again I'm only using it as an AP for my pfSense router. One thing I did notice is that they've taken out the telnet option in the debug section which is really unfortunte, they've also added a new option to "Disable Channel Switching".
- TopologyAug 20, 2020Virtuoso
iKarel and Lurksalot, I am not using ReadyCLOUD, and thus have no information to share on that topic, unfortunately.
- TerryPhSep 08, 2020VirtuosoReadycloud is not working for me with .128 version
