Topology
Aug 11, 2020Virtuoso
RAX120 Firmware 1.0.1.128
A firmware update (see here) is now available for the RAX120: New Features and Enhancements Supports the ISP profile menu, which includes ISPs from Europe and Asia Supports Orange France IPTV ...
ArunGupta
Aug 29, 2020Apprentice
I just upgraded the firmware to 1.0.1.128 and ReadyCLOUD seems to be working for me via internet (http://readycloud.netgear.com/). Initially, it did not work. I reviewed all settings, unregistered the router, re-registered it, but it still did not work. It kept showing the RAX120 with older firmware version and kept throwing a long string of number in the error message after I tried to access the storage. So I just started reviewing all settings. I am very sure that I did not change any setting except turn off the media server. Then suddenly the ReadyCLOUD access from internet started to work. Now it is showing the correct firmware version. It is vey weird. Android app also works fine. I had to logout and log back in.
I used the web GUI to upgrade the firmware and did not do any factory reset. Router is running in AP mode.
