Ghost45
Feb 19, 2021Initiate
Rax120 firmware 1.2.0.16
Every time i upgrade to the latest update 1.2.0.16 i have issues trying to connect with Facebook app. I sold have to jump off the wifi to gain access again. Rolled back the firmware to 1.0.2.136 and t...
AlessioP
Feb 20, 2021Aspirant
Yes, same problem in Italy. The firmware 1.2.0.16 does not allow Internet connection through devices connected to the router with the Ethernet cable, only Wifi works. Solved through a downgrade to the firmware 1.0.2.136
- NewfiedroolFeb 21, 2021Virtuoso
It's a known issue, I would go to the support page and download the .16 then manually over a wired connection install the firmware then you must reset the router and setup as new.
that should solve your lan issues.
- Ghost45Mar 09, 2021InitiateI have done so in the meantime. I have even upgraded and did a factory reset as also recommended. Both have resulted in the same issue. The weird part is for me everything works but once you try to access anything Facebook owned it doesn’t want to load.
