Topology
May 11, 2021Virtuoso
RAX120 Firmware 1.2.1.22
A firmware update (1.2.1.22) is now available for the RAX120 (see here): New Features and Enhancements Supports the new device notification feature. Improves system stability. Security Fixe...
soeun
May 11, 2021Apprentice
Mine auto updated last night at 3AM. After update, all my wired connections stopped working. Wireless connections continued to work. Same issue as last firmware with VLAN Tagging and PPPoE. However, I tinkered around and created a new VLAN Tag group and enabled only the physical ports and same VLAN ID as previous. That did not work when I applied so I deleted the newly created VLAN Tag group and hit applied and all of a sudden all wired connections started working again. Hope this helps with anyone dealing with Centurylink, PPPoE and VLAN Tag requirements.
