gardenstate
Feb 14, 2020Tutor
RAX120 FIRMWARE RECENT UPDATE ISSUE
Hello, This problem also ocurred I believe back in Septemeber and it was a bad firmware update. Just recently it updated to V1.0.1.114 since then internet goes in and out same as it did in Septembe...
Retired_Member
Oct 12, 2020I've been so stupid getting this update and after that have my router set to its factory default. I have to reconnect my garage, switches and everything connected to my devices all in all 32 devices and its taking me whole day to reset all of them. WTF is going ON! can we get a
stable working firmware for a very expensive router! This is my last investment on netgear products, besides I never get any support from them. My R8500 is just sitting on my closet which also very expensive when I bought 'em. I even bragged them to my frends the first time I got them and never change the SSID so my neighbors can see a latest gadget from NetLoss este Netgear!
Newfiedrool
Oct 12, 2020Virtuoso
It pays to write down your credentials so that all your devices reconnect after an update if you reset.
happly running .136 and no major issues.
when you reset it does not return to factory default firmware and by downgrading you need to be aware of security risks.
most of us who know NG routers tend to perform a factory reset after updating.
