guccia123
Apr 19, 2025Aspirant
RAX120 Firmware Recovery
Hi, I have Netgear RAX120V2. It is stuck in bootloop. Need help with recovering it. I have connected to via ethernet to laptop and manually set it to 192.168.1.10, 255.255.255.0, 192.168.1.1. I ...
Apr 19, 2025Guru - Experienced User
Try a 30-30-30 reset on it and see?
- michaelkenwardApr 19, 2025Guru - Experienced User
Sigh.
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
It isn't usually advised on newer routers, but what the heck?
Disclaimer: Just another user with time on their hands.
- FURRYe38Apr 19, 2025Guru - Experienced User
I was told my NG that this is supported as a last resort option on newer NG routers. This may have not been the case with older routers. I have done this on a few newer routers and it worked.
- guccia123Apr 19, 2025AspirantStill power light is blinking, nothing changed.
If that failed then router needs to be replaced.
