Bluejacket
Dec 16, 2021Guide
RAX120 firmware update from v1.0.1.108. Is there a stable version?
Hello, I bought a RAX120 more than 1 1/2 years ago. I had one previous to that and had issues with it. I had posted on the community about it. I setup the new one and it has been running fine. Unfort...
Dec 16, 2021Guru - Experienced User
I haven't seen a ton of post on the latest firmware.
What I'd do? Make a backup of your current configuration.
If you upgrade and it sucks, you can always downgrade back and restore your configuration.
If you do have issues after upgrading, I'd factory reset before downgrading.
