pgjscottieuk
Oct 01, 2019Guide
RAX120 firmware update
Hi my RAX120 keeps going offline and i have to reboot the firnware is up to date but i am confused the router shows its firmware as V1.0.1.90 but on the Netgear website it shows the current version ...
- Oct 01, 2019
Once in a while the update rolls out to the auto-update server before it goes to the support server and vice versa. Causes issues but your firmware is probably the correct one.
With the new RAX devices, anytime they're having issues after a firmware update, I'd recommend a reset back to factory as thats helped with quite a few of the issues I've had with mine. I've got the RAX200 and whenever an update causes a problem, I factory reset it and it tends to resolve them.
Also, did you do the update over a hardwired connection?
pgjscottieuk
Oct 01, 2019Guide
Hi thanks for your reply factory resetting is all very well but then i have to reconfigure the port forwarding things i have etc
For the money this router is rubbish i wish i had stayed with the free ISP router and saved £350
Oct 01, 2019Guru - Experienced User
You can make a backup configuration of your device. If the firmware changes to much, the backup can cause issues but they're usually fine.
It is part of the price you pay for buying a draft AX device. Its a new wireless standard that was just ratified last week. There's going to be issues and the firmware is more beta candidate than release candidate. But most of the router manufacturers are having issues if you read their forums. Its not been a smooth transition from wireless AC to wireless AX
