Aussie7734
May 01, 2020Aspirant
RAX120 firmware upgrade performance issues
Hello i am a novice at networking my configuration 1. CM1000 Modem - Mediacom provider 2. Cat6 connection from CM1000 modem to RAX120 AX router 3. Cat6 connection from RAX120 to GS324TP switch ...
May 01, 2020Guru - Experienced User
Anytime there's an issues after a firmware upgrade, a good first step is to factory reset the device and manually re-install it. Reason why is potentially the firmware changed enough that a setting caused issues. Its especially true of the RAX devices because they're so new and getting quite significant changes
I'd try that next time.
Aussie7734
Thanks - hitting factory reset after firmware upgrades would wipe the upgrade no? Also would you recommend factory reset on all components - modem, router and switch? To get all in synch again?
- NordicBastrdMay 06, 2020Apprentice
No the factory reset in this case just sets the settings back to a clean slate. The firware version stays the same.
- Aussie7734May 06, 2020Aspirant
i reset entire system - Modem , Rax120 Wifi router and Gs324tp switch....at point of setting up RAX 120 wifi went straight to latest patch 122 vs previous approach of upgrading....so far been 3 days with no performance issues with wired based devices.....having a little bit of trouble getting my mesh routers figured out but will attempt redo on those later.
cheers and thanks for help
- plemansMay 06, 2020Guru - Experienced User
Glad to hear you got it working!
Mesh routers? If you're running more than 1 router, you'd want the mesh routers in AP mode.
sorry i want to make sure i am using right terms...appreciate the help...is mesh extender and routher one and the same ?
so i have a multistory home and had pockets where wifi was non existent...so i bought 2 EX7700 Extenders.......followed the instructions for setup and placed on different floors in house - basement (ex7700) and ground level(ex7700) with primary wifi routher (RAX120) on top floor
do i need to set the mesh extenders to "AP" mode....what is that and how do i do it....
