Aussie7734
May 01, 2020Aspirant
RAX120 firmware upgrade performance issues
Hello i am a novice at networking my configuration 1. CM1000 Modem - Mediacom provider 2. Cat6 connection from CM1000 modem to RAX120 AX router 3. Cat6 connection from RAX120 to GS324TP switch ...
Aussie7734
Thanks - hitting factory reset after firmware upgrades would wipe the upgrade no? Also would you recommend factory reset on all components - modem, router and switch? To get all in synch again?
NordicBastrd
May 06, 2020Apprentice
No the factory reset in this case just sets the settings back to a clean slate. The firware version stays the same.
