Redtulips7
Aug 31, 2020Luminary
RAX120 Firmware Version 1.0.1.128 BUGS DFS>>>NON DFS
RAX120 — Nighthawk AX12 with new FW 1.0.1.128 DFS Channel change to Non DFS Channel #44 regardless what DFS Channel I choose.I never had this problem any old FW. I always reset the Router after the ...
Killhippie
Aug 31, 2020Prodigy
Not having that issue here, defaults to DFS 100 for myself in the UK using 80Mhz. Have you tried reinstalling the fiormware and factory resetting again. Try doing it via a browser not the app, even though there is a bug where the browser auto set up routine does not start up, you have to type in routerlogin etc yourself. Mines been fine on channel 100 primary for a few weeks now. Also be aware that the current fiormware fixes security issues that the previous firmware does not.
Redtulips7
Killhippie wrote:Not having that issue here, defaults to DFS 100 for myself in the UK using 80Mhz. Have you tried reinstalling the fiormware and factory resetting again. Try doing it via a browser not the app, even though there is a bug where the browser auto set up routine does not start up, you have to type in routerlogin etc yourself. Mines been fine on channel 100 primary for a few weeks now. Also be aware that the current fiormware fixes security issues that the previous firmware does not.
I redownload the FW through Software(Routerlogin.net)and did the hard reset in to the Router instead Erase from Software, now I can see DFS Channel stable again.
- TopologyAug 31, 2020Virtuoso
The “Disable Channel Switching” option in RAX120 firmware 1.0.1.128 (routerlogin.net/debug.htm) might be of assistance.
