Redtulips7
Aug 31, 2020Luminary
RAX120 Firmware Version 1.0.1.128 BUGS DFS>>>NON DFS
RAX120 — Nighthawk AX12 with new FW 1.0.1.128 DFS Channel change to Non DFS Channel #44 regardless what DFS Channel I choose.I never had this problem any old FW. I always reset the Router after the ...
Redtulips7
Killhippie wrote:Not having that issue here, defaults to DFS 100 for myself in the UK using 80Mhz. Have you tried reinstalling the fiormware and factory resetting again. Try doing it via a browser not the app, even though there is a bug where the browser auto set up routine does not start up, you have to type in routerlogin etc yourself. Mines been fine on channel 100 primary for a few weeks now. Also be aware that the current fiormware fixes security issues that the previous firmware does not.
I redownload the FW through Software(Routerlogin.net)and did the hard reset in to the Router instead Erase from Software, now I can see DFS Channel stable again.
Topology
Aug 31, 2020Virtuoso
The “Disable Channel Switching” option in RAX120 firmware 1.0.1.128 (routerlogin.net/debug.htm) might be of assistance.
