sgopal2
May 13, 2020Star
RAX120 Frequent Crashes
Hello, I've had the RAX120 for a few weeks now. Just upgraded to the latest firmware (V1.0.1.122) the next day after it was released. Before the firmware update, everything was smooth. But just a...
Newfiedrool
May 13, 2020Virtuoso
Perform a factory reset using the rear pin hole method. Set up as new without using a saved cfg.
see if that solves your issues.
sgopal2
May 13, 2020Star
Thanks for the feedback. So it sounds like you think the culprit is the new firmware? Reseting to factory settings would go back to the original firmware. Happy to give it a try.
- NewfiedroolMay 13, 2020Virtuoso
When you perform a factory reset it does not default to the original firmware. A reset clears out the Nvram of low level stuff.
normally it's best to perform a factory reset after an update but many don't but issues can pop up.
