sgopal2
May 13, 2020Star
RAX120 Frequent Crashes
Hello, I've had the RAX120 for a few weeks now. Just upgraded to the latest firmware (V1.0.1.122) the next day after it was released. Before the firmware update, everything was smooth. But just a...
May 13, 2020Guru - Experienced User
What I'd start with?
A factory reset and manual reinstall. Any time theres an issue after a firmware upgrade, that's a goodl place to start. Potentially an old setting could be carried over improperly and causing the issue.
Have you tried this?
- sgopal2May 13, 2020Star
Ok thank you all. I'll do a reset later tonight and report back. Appreciate the prompt feedback.
