sgopal2
May 13, 2020Star
RAX120 Frequent Crashes
Hello, I've had the RAX120 for a few weeks now. Just upgraded to the latest firmware (V1.0.1.122) the next day after it was released. Before the firmware update, everything was smooth. But just a...
May 13, 2020Guru - Experienced User
What I'd start with?
A factory reset and manual reinstall. Any time theres an issue after a firmware upgrade, that's a goodl place to start. Potentially an old setting could be carried over improperly and causing the issue.
Have you tried this?
sgopal2
May 13, 2020Star
Ok thank you all. I'll do a reset later tonight and report back. Appreciate the prompt feedback.
