sgopal2
May 13, 2020Star
RAX120 Frequent Crashes
Hello, I've had the RAX120 for a few weeks now. Just upgraded to the latest firmware (V1.0.1.122) the next day after it was released. Before the firmware update, everything was smooth. But just a...
smoothster
Jun 04, 2020Star
I had the same stability issues with V1.0.1.122 losing connectivity at least 10 times a day. I tried both upgading and a factory reset with the same problems
I ended up loading V1.0.1.118 and everyhting is now stable for 3 weeks
I am running a similar config with a CM1100 Comcast Gigabit service and a 8 Port switch. I am using WAN aggregation(LACP) from the RAX120 to the CM1100.
I have 25 devices on 5G, 14 devices on 2.4G and 14 Wired Devices
sgopal2
Jun 05, 2020Star
Hello all,
Thanks for all the valuable suggestions. Indeed it definitely appears to be a problem with the new firmware. I took returned my RAX120 back to Best Buy and switched to my old router.
My network has been up for 2 weeks+ without a crash. So it definitely was not the cable modem (CM1100). It looks like others are having the same problem. I didn't realize that it was possible to downgrade the firmware. But its too late now, I've already returned the router.
