jhamaker
Nov 02, 2022Aspirant
RAX120 fw:1.2.8.40 - Some devices connected to wifi but no internet
Hello RAX120 is about 2 years old. Firmware was updated to 1.2.8.40. Set to AP, and connects to a switch by ethernet, which is connected to a Sonic Wall. Recently we have started having a probl...
jhamaker
Nov 07, 2022Aspirant
- The first 3 digits of the serial number are 67T.
- Wifi devises are almost exclusively cellphones and non-domain laptops. But there are a couple of printers.
- I have changed the channels as suggested, but it did not solve this issue.
- We are in a somewhat remote area, so there is no issue with wifi from neighbors. The only other wifi is from the Comcast wifi unit we are not using.
Since posting my initial query, I have found the users who are connected but not getting wifi are receiving a bad ip/gateway when they connect. Our default gateway is 192.168.1.1. However, these users are getting an ip address of 192.168.0.X and a default gateway of 192.168.0.254.
I didn't mention in my original post, but the RAX120 is being used as an access point, not a router. DHCP is being handled by our server, and we are not having any issues with wired connections. Most wifi devices are not having a problem. The main reason I'm looking at a router problem rather than a phone problem is it's happening on both android and iphone.
michaelkenward
Nov 07, 2022Guru - Experienced User
That makes all the difference. Most problems will be down to what is happening with your (unnamed) router.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
It may be a router problem, but it won't be with the RAX120 in AP mode. It leaves management to the router.
And, as you have no wifi problems with most devices, it isn't likely to be a router problem either.
When one set of wifi clients has problems, the logical place to look for the solution is with the wifi clients.
Maybe this?
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
Recent Android is in the same boat.
