Blixt
Jun 20, 2020Aspirant
RAX120 GUI vs EAX80 GUI
Why do two devices of the same physical design language have very different web interfaces? The RAX120 GUI isn't perfect but it is much better (not as playful) as the EAX80's GUI. Why are they any di...
Jun 20, 2020Guru - Experienced User
Because one's a router and one's an extender?
You have different capabilities from a router to an extender.
Blixt
plemans wrote:Because one's a router and one's an extender?
Different functions means the router has other features like port forwarding and DHCP settings in the menu whereas the extender does not. Certainly. Give us the same menu but leave those settings out.. What I am getting at is the menu design makes them look like different brands alltogether. For example, remove the Nighthawk or Netgear logo from the web admin page and they are nothing alike.
Get inside the cab of a Ford car of any year model, and then get inside the cab of a different model Ford, but same year, and you will be able to tell it is a Ford without looking at the Ford logo.
Netgear clearly understands design language because both devices have the same "stealth bomber" look of flat black and "curved angles", but it stops at the physical appearance.
Just me ranting and hoping maybe they actually notice and make their GUIs more congruent.
