Ar3
Jul 06, 2020Tutor
RAX120 Internet drops on iPhone
Hi all - I am having an annoying issue with my RAX120 that I really hope you can help me fix! A few times per day, I lose internet connectivity on my iPhone, until I toggle the wifi on and off, whic...
Ar3
Jul 19, 2020Tutor
Anyone else have something like this happening? Its still happening and its still annoying for a $400 router to be doing this :(
rinthos
Jul 19, 2020Luminary
Ar3 wrote:Anyone else have something like this happening? Its still happening and its still annoying for a $400 router to be doing this :(
What type of Modem do you have? Is your modem also asking as a router by chance? If so, either disable that or change your Router to Bridge or AP-only mode.
Also try turning SmartConnect OFF and see if that fixes the issue?
Have you updated the firmware on your router?
What version of iOS and what model iPhones are you using that all exhibit the same issue?
