Ar3
Jul 06, 2020Tutor
RAX120 Internet drops on iPhone
Hi all - I am having an annoying issue with my RAX120 that I really hope you can help me fix! A few times per day, I lose internet connectivity on my iPhone, until I toggle the wifi on and off, whic...
Ar3
Jul 18, 2020Tutor
Anyone else have something like this happening? Its still happening and its still annoying for a $400 router to be doing this :(
NordicBastrd
Jul 28, 2020Apprentice
Basically that is the same issue that occurs in this thread:
In that thread it is talking about how the speeds drop but the actual negotiation still stays at high speeds. Just actual traffic is basically useless. On mine if I do a speedtest it hiccups a bunch before spitting out around 6 Mbps but because of those hiccups internet usage is for all intents and purposes dead. The solution is to return the router if you still can and get something that works. I would suggest amplifi alien or Asus
