Retired_Member
Oct 26, 2023RAX120 internet speeds slows when using the MGig port with a CM2000
When connecting from my new CM2000 to the RAX120 using the MGig port, my internet speed drops from 900Mps (800 Mps service) to 650Mps. The Nighthawk IOS app test speed says it's working, but my hardw...
- Nov 01, 2023
Wow, thanks for letting us know and the details.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Retired_Member
Nov 01, 2023Hi, Thank you for your support. I have been working this issue for weeks. I did some additional research on the internet.
There was suggestion to do a computer network card reset and it worked. I’m using the MGig port on the router and the PCs are back to the prior speeds.
- So, for Windows 11, go to ‘Settings’
- Select ‘Network & Internet’
- Select ‘Advanced network settings’
- Select ‘Network reset’
- Select ‘Reset now’
- The PC will automatically shutdown in 5 minutes or do a manual shutdown (a PC ‘Reset’ is not sufficient for the change to take place)
This restored my PC connection speed. Still can't explain the behavior.
Again, thank you for your effort. Modem and Router seem to be operating correctly. Case closed.
Nov 01, 2023Guru - Experienced User
Enjoy. 📡
