Wldmnk
Jun 11, 2022Follower
RAX120 is blocking my gaming apps
Rax120 with firmware version v1.2.3.28 I have spectrum internet with a spectrum modem connected through eth cord to a spectrum router. The spectrum router is connected to the RAX120 router by eth...
Razor512
Jun 11, 2022Prodigy
Are you using any VPN software? If so, check to ensure that your split tunnel settings didn't get reset.
If you are using the Netgear router behind the spectrum router, then make sure that the spectrum router is in a bridge mode,and also make sure the bridge mode didn't get disabled as that would put you behind a double NAT which will wreak havoc on most online games.
