Sgtaylorc
Oct 24, 2020Aspirant
RAX120 Is forcing Auto Firmware Update Every Night
My Nighthawk RAX120 keeps automatically updating to V1.0.2.136 firmware at 01:00, even though I have disabled the “router auto firmware update.” Essentially when the router updates to the newest ve...
Killhippie
Oct 29, 2020Prodigy
Can you explain why you are running such old firmware? There has been 3 updates since that version. Why dont you use 1.0.2.136 (not 1.0.1.136) factory restet that version and set up manually and then go to your devices and set up them to connect to the RAX120 in case there is an issue with them not seeing the RAX120. I do not have this does not connect issue so Im a but lost as to why they cannot see the RAX120. Surely you would have re added them again to make sure they can see what channel you put them on, or what they selected if you use autochannel select hell.
